True, but in my experience the difference is minimal... Since a deck rarely, if ever, puts out its maximum voltage its more of a non issue, when I tune amps I like a little gain overlap anyhow (I bump the gains a bit higher than the rated voltage, course the best way is to match it with an o-scope/pink noise) since music is dynamic. (Do this at your own risk anyone reading, if you haven't done it a few times its a really good way to cook speakers) Plus, in my opinion, it seems many of the amps on the market are more designed to a 2ish volt signal, I have a few older amps that state they can only take 3V max. Now in home audio, you can get some crazy preamp voltages, and it makes a big difference, the amps do run cooler... But, I haven't found any noticeable difference in temps in different voltage preouts since the span isn't very big, but it definitely allows for a quicker and dirtier install b/c since its less noise susceptable. But, like I said, these are observations, don't ask for scientific backing, LOL.
