Pro Comp AAL 13133? | Ford Explorer Forums
Pro Comp AAL 13133?
Lone_Wolf
Forest VA
2005 ST 4x4
Anyone know if the 13133 kit will for for an 05 Trac? If so would I expect to need to return to stock shackles in order to maintain the ride height I'm currently at? Or will the warrior shackles be ok?
Also, what is the advantage of a "long AAL vs short"?
That part will work for the ST.
The short AAL is cheaper. The long AAL is more expensive, but it will ride a little bit better than the short one.
You can expect to get 1.5-2" of lift from the AAL, so if that lifts your truck more than you want, you'll want to remove the warrior shackles. If you like a little bit of forward rake, then you might be okay to leave the warriors in there.
Solid thank you!
