problem with front right body mount, | Ford Explorer Forums
ExplorerX91
Yakima, WA
91 XL
ok we got the whole passanger sides out and we have it jacked up and a couple of spacers into it but the front mount is loose and out but we only got the nut out but its still threaded and theres no way to get the bolt out of the bushing, any suggetsions?, its stuck in the lil metal thing inside the bushing
had the same problem...had to take a sawzall and cut it off, then replace the bushings (actually, i had the problem on both front ones, one i salvaged and the other i scrapped.
do a search for my user name and "gone sour" you should find my threadf where i detail my BL and all the peoblems i faced (hint, i only had 4 bolts of 10 come out peacefully).
well we cut the bottom of with a hacksaw then put it in a vise and sprayed pb allover it then turned it out with a pipe wrench,
but thanks anyways ;)
