problem with oil pan drain hole | Ford Explorer Forums
billy97xlt
Indiana
98 F-150
ok so I was changing the oil and the oil pan drain hole is stripped.... (at least this is what I think) I am leaking oil and when I put the oil plug in it starts to get tight and then it gets loose again and the starts to get tight..... well I think you get the pic on that. I have also tried a new oil plug. is my only option to get a new oil pan?
There is a re-threading tool that you could buy from a hardware store to get the thread back. You might have to change to a bigger size bolt to get the right fit.
thanks for the idea i might just give that a try
they also sell oversized drain plugs.... i have used some, but they only work about 50% of the time without problems....
Heli Coil
You can get an insert kit at just about any parts store, Heli coil - you drill and tap the hole for a spiral insert thats put in with a special wrench- it allow you to use the standard plug.
Make sure you use a new washer with the plug after every couple of changes. A worn washer encourages you to crank down on the plug to get it to seal.
Good Luck
