LeKid302
- December 10, 2006
- Montreal, Canada
- '96 AWD V8
I have a Polar remote starter on my X , it was there when i brought the truck so i don t know how it works .
The problem is 50% of the time i start with no problem but often the starter keep engaging even after the engine had started . I check under the hood and i found that the purple wire was hooked to the coil but have been cut and now i hooked to #5 injector .
Sometime it work , sometime not . If i start with the key it start perfectly every time .
Thanks .
Thanks .
