DavidKyle
- September 12, 2011
- 1998 mountaineer
Have '06 explorer 2wd. Needed new rear pads and changed them with no problems. Did not turn the rotors. Was not having any problems with the rotors. Next day begin hearing a low rubbing sound from the driver's side rear wheel. It has gotten louder. It only occurs at low speeds, stops when the brakes are applied and will stop for a bit when the vehicle is backed up and brakes are applied 4 or 5 times. I have looked back at the install, re-lubed the slides but with real change. I also noticed on re-exam, when the vehicle was up on stands, the noise did not occur when it was in gear and the wheels were turning. It stops fine and there is no noise above 20mph or so. Any thoughts or ideas.
