supra77r
- June 3, 2006
- Dallas, TX
- 97 F150 XL
97 F150 2wd 4.2L.....4R70W Tranny.
My direct clutch burned up and I lost 3rd and 4th gear, so I pulled tranny and replaced direct clutch pack. All other friction and steels looked good and didn’t replace them. Replaced all sealing rings and as many seals as possible and gaskets. Put tranny back on truck.
On take off in Reverse the truck hesitates bad. A good way to describe it is it feels like it would if you had your back brakes(emergency) applied and try to reverse. Eventually it stops.
Then when I put it in Drive to go it does the same thing but very mildly compared to Reverse and stops once I get going. The is no more hesitation at all after that. Another thing is that it doesn’t seem like it shifts right. Randomly it will downshift on light acceleration around 55mph. I’m not even sure if that’s a problem or not yet because I haven’t drove it enough for the computer to completely reset and get used to the driving, because I have unplugged the battery so many times in between to mess with other stuff(blinker switch etc..). When I press the OD Off button the light comes on but no effect (downshift) at all. I’m not even sure OD is working or not either. It’s hard for me to tell how many shifts I get because when I was removing the tranny and couldn’t get the exhaust off in one piece so I cut the muffler off (long story). So it is kind of loud. Also it shifts SO SMOOTH that it is very hard to count shifts or even tell. I am able to drive it on the highway at high speeds 70mph 75mph and seems like my rpms are ok and not high. Hard for me to tell exactly what they are because I have no RPM gauge.
One other thing that is happening is on acceleration around 20mph - about 45 randomly it will make a clicking tapping knocking noise rapidly which sounds like its coming from the tranny but not sure cause only does it when I’m accelerating and cant check it good. I can usually avoid the noise if I barely press the gas pedal and ease up to past 40mph.
Also I do have a VERY SMALL leak. I get about 1 to 2 tiny drops leak every 20 miles that comes out the TC bottom inspect plug.
I’m pretty much stumped now. The truck drives good and smooth once you get going but I know if I don’t take care of these things then it will screw up soon. Could any of this be the rear end? Like maybe the rear diff causing the shudder and hesitation on take off in REV and D? Maybe the exhaust to manifold bolt plates causing the noise? Doubt that because it sounds exactly like a VB valve tapping rapidly to me. Any help would be great..
