problems in front differential ? | Ford Explorer Forums
PROTEUS
El Salvador, America Central
Explorer 91 XL
I engaged the 4x4 in my exp 91, and I could hear a loud sound from the front...
I check the front axle today, and I felt the passenger side of the front axle some loose or free (not rigid) in the part closed to the differential , especially when I move the axle up and down... there is a little leak of fluid from the right bearing of the diff, also.
The passenger side of the axle spins when I engage the 4x4, so I can think the axle is connected inside the diff.
A problem in the diff ? any seals problem? a bearing problem ? ... or is it normal ???
Thanks for your helpful responses.
the noise and the play seem to be normal.... is there a lot of fluid leaking? or is it just remnant road grime on there or something?
Every day that I see it, there is a drop of fluid, but the level is OK, I never have refilled the diff.
sooo... the sound and play are normal???? uh!! , I'm surprised!!
its the way the 4x4 works on the older explorers... the autohubs make them do funny stuff....
