Problems While Changing pcv Valve Need Help!! | Ford Explorer Forums
dexboy15
LUBBOCK TEXAS
1999 FORD EXPLORER
Ok So I Was Changin The Pcv Valve And Came Across A Tee On Top Of The Valve And As As The Forum Said Dont Worry Just Fix It By Yourself Since This Is Common Now. The Part I Had From Motorcraft That Was Installed It Was A Ev-147 The New Part I Got Is From Purolator....part Number Pv225 When I Googled The Motocraft Part It Said It Was Used On Cars Like The Escort Now What I Did Was To Use Some Epoxy On The T To Get It Together To The Metal Pcv Valve ...but Now The Trucks Seems Not To Start...is It Possible The Pcv Valve Wont Let The Truck Start??? And Is The Flow Suppose To Come From The Up The Valve To The Hoses Or From The Hoses To The Valve???
