sean4385
- May 2, 2003
- Hopewell NJ
- '97 Sport
I just noticed the other day that the tread on one half of each of the front two tires is MUCH more worn down than the other half. This only applies to the front two tires. the half of the tire facing the inside of the car is almost completey worn down, while the half of the tire facing away from the car looks unused. I have BFG ATs which are almost brand new, i bought them only a few months ago. The tire pressure is around 40psi, which is what they were set to when they were put on my truck. I have kept the pressure at this point since ive had them thinking that what they had it set to was the correct psi. On the tire it says the max load is 65 psi, but that seems very high to me, besides, when they are at 40 they seem to be inflated pretty well. I am about to switch my front 2 tires to the opposite sides to try an even out the wear, but even still the inner half of the tread wore down way too fast, and id like to prevent them from being useless in only a few more months. So if anyone knows why this is happening, or what psi bfg ats should really be set to, id really appreciate the info.
Thanks,
Sean
Thanks,
Sean
