Project "Twisted Sister" SAS Front Dana 44, Rear Ford 9" | Page 3 | Ford Explorer Forums
My 99 did not have a speed sensor in the transfer case, I have a manual 1354 case note with no sensor and the speedo works from the rear did sensor. I believe the 95-98 trucks did have a sensor in the transfer case
Either way he can still put the tone ring in the 9"
You are correct, some do and some don't, apparently it depends on the type of instrument cluster i.e. electronic/analog and whether it has the 4 or 5 speed automatic. The 2000 mountaineer did not come with a manual t-case.
Second gen = 1995 -2001
The speed sensor is in the transfer still on a 2000. The tone ring in the diff is only for the ABS.
You can mount the tone ring in the 9". You need to grind out the case a bit for clearance and drill a hole for the sensor. Not too tough if you have the right tools. You can, for a couple hundred bucks have a machine shop do it up.
Best part is you only need to carry the 3rd member and not the entire housing to the shop.
Here's a link with pics of a 9" with the tone ring mod.
http://www.therangerstation.com/forums/showthread.php?t=89605
This would be the better way to go than mess about with wheel adapters. Cheaper too.
But if the tone ring is in the transfer case why do i need to put one in the axle?? wouldnt the speedo work of the transfer case then?
i should add that i am going to do the BW4406 manual tcase swap soon.
and i honestly think figuring out how to convert the 9" from drums to rotors will be way more expensive and complicated then regears/ locking the 8.8 and throwing some adapters on it.
