dersch6221992
- June 16, 2009
- Indiana
- 2000 mounty
Brian pretty much nailed it. Some guys get a little carried away with the radius arm length. At some point there's diminishing returns and your radius arm brackets are put in a vulnerable spot for damage.
The tie rod flip moves not only the tie rod but the drag link up as well with less angle which is desirable to help combat bump steer.
Whichever method works for you to measure drive shaft slip...go for it. With the d shaft in or out you need to get the measurement from yoke center to yoke center or yoke center to the face of the flange...whatever the case may be.
Wow that wristed arm looks super easy to make! i think i will go ahead and do that... so basically does it matter what side i do it on? i think ive seen mostly passenger side done.
tie rod flip makes sense.
hmm. that makes sense wit just letting the axle be and do the driveshaft afterwards.
