PSA: Check your rear sway bar bushings | Ford Explorer Forums
cross6
Baton Rouge, LA
2004 Mountaineer
Went to do rear brakes today and discovered both of my factory rear sway bar bushings totally popped out of their brackets.
Bracket nuts were still tight. Rear end wasn't making any noise, but I'm sure cornering was affected.
Were your sway bar links damaged because of the "extra" movement ?
I recently had a surprise with the front sway bar. I'll post up some pics tonight!
Nope, they were still supple, springy, and tight. In fact, I had to pry on them a bit to get the sway bar back into place and they were tight and bounced right back.
Now that I'm thinking about it, the dealer replaced the rear links under warranty a few years ago...I wonder if they are responsible for the chewed up/failed bushings...
Interesting. If you make a new thread post a link in here.
Will do. Forgot to get pics yesterday. Should be able to get them tonight.
