push button 4x4 | Ford Explorer Forums
push button 4x4
BulVii
Mesa, Arizona
'92 xl 4x4
Just bought 92 4x4 explorer xl 2dr. I cannot tell if the push button works. I push the button and nothing happens. I will greatly appreciate any advise on this matter.
Search
Welcome aboard!!!! I'm sure you'll be adicted to thos board. Use the search feature on top of page, put 4x4 not working or somthing like it, you'll find tones of post relating this subject. If it does not answer your question try Dr Bob page at Dead Link Removed under hub,t-case.
That site really is great. I had the same problem as you with my push button. I took apart the motor cleaned it and put in manual locking hubs and it worked. Unfortunately it concked out so i have coughed up the dough for a new motoe. $179 from www.fordpartsonline.com good luck
it may not be the motor... there are a few tests that yuo can perform.... 4x4 should work on pavement but it will make the car barely move.... then low range youll have to be stopped and in neutral and already in 4x4.....
oh yeah, if you try to do the pavement test, dont do it too long as 4x4 on pavement breaks parts due to stress....
