bluevolume
- May 2, 2000
- Rochester, NY
- 2001 XLT
I want to make a few mods to the factory system in my 2000 XLS, but don't want to change the head unit. I've had 3 stolen, don't want to deal with it anymore.
First question is with the speakers in the doors. I know that Pioneer makes some 3-way 6-8? that replace the OEMs, but are they worth it? If it will make a noticeable difference then I'll go for it. What I don't like about the orignals is that they get a little muddy with highs, and the mid-lows sound too boomy.
I'm probably going to add some insulation under the door panels while I have them apart, best idea I've seen yet is the furnace pipe wrap stuff from Home Depot. Any other cheap solutions?
Finally I want to add a subwoofer in the rear storage bin thing (where the original one would be). I plan on designing the box myself and building with some 3/4" MDF. I'm not sure what to do about the amp -- is there room to put it above the fender (where they used to put the amps?) And how should I connect it to the feed from the head unit -- do I need to get a line-level converter or just use the high-level input on my amp?
Any other suggestions would be great too.
Thankx,
Blue
Thankx,
Blue
