Lemondrop
- August 28, 2001
- Cocoa , Florida
- 1995 Sport , 1996 XLT 5.0
My wifes explorer 5.0 (1996) is having a problem with waking up to a dead battery . The battery is 1.5 years old and I had the battery checked and it is fine . You can run the truck all day and it starts fine . Just after sitting 10 to 12 hours it will not start without a jump .
I hooked my amp meter up and started checking . I have a half amp draw with nothing on . I figured the PCM would need some amps to keep alive and also the radio but the .5 amp is a tad much methinks . I started pulling relays on the engine relay panel and then the fuses behind it . WHen I reached the "Battery Saver" relay It dropped to .07 amps which is more in line with keeping memory . I was going to pull the battery saver relay but I can't find it off the owners manual's description ...... it shows it in the lower middle of the windshield
I tried the headlights with the fuse (30 amp fuse) and the headlight would come on but no park lights so obviously I can't leave this fuse out to prevent a dead battery . The interior lights are not staying on and Ive verified this by monitoring the amp meter and watching the lights/amps go up/down/on/off .
Anybody got a clue ? Im hoping the friggin GEM is not a dead duck ...... I guess I could hook my Diagtek up and do a GEM test .
Shoot me some ideas if you guys got any .
