Question about my 00 EB | Ford Explorer Forums
lugmynuts
Oak Harbor, WA
00 Eddie Bauer
Hi guys, I am new. I used the search. Now for the question.
I just bought my 00 EB with 40k mile and I had the common "Non-Worky Display" so I replaced the headunit. After i replaced the headunit i decided i want new speakers all around. Now when i get on crutchfield to enter my vehicle data it asks if i have Premium or Mach. How can i tell which i have? I had the 8" woofer in the back if that helps.
Thanks Guys
Jason
the speaker size is 5x7 /6x8
I didn't know they offered the MACH audio in Explorers.
All I've ever seen had either the stadard or Premium.
I would assume you have/had the premiun system since you had the stock sub. The speakers will not be any different. The major difference between the standard & premium system is the wiring harness. The MACH may have had more than the standard four speakers.
The premium system had the HU amp located in the rear cargo area behind the plastic panel. The amp for the sub is located there as well.
