Kamaaina
- January 12, 2003
- Hawaii
- '96 XLT 2wd
When I fade the music to the front speakers the bass is strong. When I fade the music to the rear the bass is also strong. When I fade to the middle position the bass seems to get weaker from both front and rear. I made sure that I hooked up the speakers properly. Is it true that if I have one set of speakers with the wrong polarity it will cancel out the other speakers? Before I installed the speakers I made sure that the + and - were correct by using a AA battery and seeing which way the cone kicks and then hooked up the "hot" lead and common lead correctly. Oh, by the way, this is with the OEM head unit. When the fader is split in the middle do I lose some of the bass because it is being split four ways?
