Question on sythetic differential fluid type. | Ford Explorer Forums
Harry5150
Santa Clarita, CA
05 Dodge Durango Limited
I'm replacing a seal in my diff this weekend and would like to put in synthetic fluid.
It looks like Amsoil is the type most folks here use. What grade should I use? I belive it's 80W90 (Ford #XY-80W90-QL) for a 4.0L 2WD w/ a LS differential.
This is the one I'm looking to get:
Dead Link Removed
Or is the Series 2000 fluid the one I should get. It's a different weight though.
Dead Link Removed
The owner's guide says that the 5.0L with conventional and LS differentials comes with Motorcraft Premium synthetic already.
Am I to assume that the 4.0L use regular gear oil even thought the axles are the same for both. Is it ok to switch to synthetic?
Thanks,
Harry
I would go with the series 2000. I think that is their top-of-the-line gear oil. The 75W90 will be slightly thinner than the 80W90 while the oil is cold and it should be fine to use. I believe the Amsoil has a limited slip additive so you might not need the friction modifier additive from Ford. If it chatters a little, add 1/2 bottle of the friction modifier and it will quiet the clutch packs.
Check my message to Yomie Dead Link Removed For a limited slip in a '97, you need Synthetic 75W140 with the additive. The Amsoil isn't supposed to require the additive it that is what you go with.
Robert -
Thanks, I just crawled under there and read the tag, "Synthetic 75W140 Only". I though the differential tag only had the gear ratio on it. Learning something new here all the time.
Harry
Harry,
The AMSOIL Series 2000 75W-90 will work fine in the differential. And without the friction modifier. The choice of the 75W-140 or 75W-90 is up to you. If you do a lot of towing and/or off-roading, the 75-140 is probably the lube of choice.
E-mail me if you'd like to purchase any AMSOIL product. I'll get it for you wholesale (about 25% off retail). You'll need about 3 quarts of gear lube for the rear diff.
