Bigham
- May 8, 2000
- 99 Explorer Eddie Bauer
I already asked some questions about the noise in my 99 eddie bauer rear end and I have some more to go. I have been doing more research and I came up with more questions.
Two posts so far:
http://www.explorerforum.com/forums/showthread.php?t=383371
http://www.explorerforum.com/forums/showthread.php?t=382631
1-today I finally got to ride in the back seat and the whining seems to be coming from the right rear wheel, but it only makes the noise on accelaration, not when coasting. Does this mean it is related to the rear end?
2-I have the D code limited slip differential (4.0L SOHC, eddie bauer with tow package). the shop replaced the diff gasket and added 80/90 weight oil. Shouldnt it be the higer weight oil because it is limited slip?
3-When I take off I hear what sounds like a grinding noise. Could this be the clutch packs? Are there clutch packs in this year/model? If I replace with higher weight oil and friction modifier could this help with the noise and feel?
4-Should I replace the fluid and drive around for a while? I already know I have a leaking left wheel bearing seal. If I need to get the wheel bearings replaced, should I just wait and have shop do all the work at once?
Two posts so far:
