Kelly6
- August 28, 2010
- New Mexico
- '99 XLT
I have a '99 Explorer XLT V6 SOHC with the dog of all problems - the intermittant problem. The problem is serious because the engine quits. It happens in near 100 degree outside temps. The "fix" is to run with the hood just open to the safty latch, so the problem seems to be engine compartment temperature. Engine coolant temp is normal.
Any suggestions as to what component would be temperature sensitive to cause this problem.
I have pressure washed the radiator to remove bug, etc. to increase air flow and so far, it is ok.
