bluexpy
- September 11, 2007
- Explorer-less
I have a strange problem that i haven't seen before.
The radiator cap is letting coolant seep out the filler neck. I looked at the cap, and it seems OK.
I haven't tested much at this point. What I've found so far is that the upper hose gets pressurized when the engine is getting warm. I did open the cap when the engine was warm, and coolant tried to spray all over before I put pressure back on it with a thick rag. When it's cold, it needs filling up. It only takes a cup or so to come up to the neck.
Is there something blocking it, or..? The hose from the filler neck to the coolant reservoir is intact.
