lakelanier
- September 8, 2013
- 1996 explorer
Changed my TS the other day so I drained the radiator in the process. Now I have a drip coming from the drain valve every ten minutes or so. Leaving a small wet spot everywhere I stop for while. I tightened as tight as I can by hand since its plastic.
Question: Can just the plastic wing nut screw be replaced or even wound all the way out to put some Teflon tape on it?
