prozachappy
- April 28, 2002
- SoCal
- 94 explorer...sportster
HELP!!! rad. upgrade sug.???...conflicting reports.
Here's the deal, I need to upgrade my radiator to keep my 1st gen 94sport cooler. I travel alot (Dallas to San Diego) at least 3 times a year. I also pull a 22 ft. camper quite often. I have the Mz5spd tranny and an OEM (1 row) radiator. Sure you can guess, that the stock rad. just doesn't do the trick. It never overheats, but on my long trips...the gauge slowly creeps towards the red. Plus on my most recent trip I cracked a seam in the rad. that I just put in about a year ago. Been researching HD radiators, and exploring my options. They don't make a 2 or 3 row rad. for the manual tranny's... unless you wanna spend the big bucks $$$ for something like a BeCool. Then it hit me...why not just use a 2 row rad. made for the automatics and plug the tran cooler. So I've called around asking if this is possible or not, i.e. uses the same mounts, enough room for the fan, and so on. Visteon rad. tells me "no" won't work at all. Modine rad. tells me "yes", but the outlet holes are angled different so I'd have to extend my hose. Radiator Barn says "yep" it will work no problem...mounts the same, inlets and outlets the same, and enough room to clear the fan. So what I need to know is if any of you guys have done this mod...or no if it will work. I search the threads, not much info...I know Rick did a similar mod to his '93' but he pulled an automatic rad. from another '93' donor. Any help would be great!!!
