Firstly, what radio is it?
Do you have a CD Changer and/or Rear Radio controls?
Do you have a subwoofer?
Sounds to me like it's a power issue.
Take the radio out and check the pins with a multimeter.
Here's the wiring info for it:
Check that the light green/purple wire has 12Vs running through it.
Then check that the Yellow/Black wire has 12Vs running through it when the key is in the on position of the ignition. That'll tell you whether it's a power issue or the radio is fried.
Also, check that the ground is solid.
Radio 12v lt green/purple +
Radio Ground black -
Radio Ignition yellow/black +
Radio Illumination red/black +
Factory Amp Turn-on
Power Antenna
LF Speaker +/- org/lt grn-lt blu/wh
RF Speaker +/- wht/lt grn - grn/org
LR Speaker +/- tan/yel - gry/lt blu
RR Speaker +/- org/red - brn/pnk
