radius arms bushings | Ford Explorer Forums
VirtualExplorer
Toronto, Canada
1991 Explorer XLT
Can anyone give me a step by step on how to replace my radius arm bushings on my 91 explorer.
And what i should be looking for
thanx
Check out Jeff Singleton's site under "list of useful threads" in the forum column. Lots of info and ideas there. Good luck.
Peace
first side will take you 3+ hours, 2nd half as much.
Forget the disassembly way ! And; Forget the grinder ! I tried both on a 91 4x4.
Disassembly 1st - The axle hits the frame before the control arm comes out of the frame mount.
Grinding rivits 2nd - After grinding the driver's side I then found out I couldn't swing a hammer to knock it out.
Then I just drilled out the rivits on the pass side. First use a small drill as a pilot. Then use a larger drill to cut away the rivit to the frame. Once at the frame, since you have a large hole in it, you can use a punch or chistle to colapse it and push it out. WAY EASIER THAN THE OTHER TWO METHODS !
I used cheap drills too. The metal is tough but soft. Just don't put a lot of pressure on the drill. As long as you see metal being cut out, it's doing it's job. A variable speed drill will help. People make the mistake of putting too much pressure on a drill bit. That burns the tip and distroys the bit.
I have used Duff's method and concur.
That's pretty funny, I was reading all of these posts and thought, "what are they saying? To change the RAB's you either take a drill and grind the rivets out or you disassemble and move the beam."
hehe. I have often used the term "grind" and "drill" interchangeably. (I of course recognize the difference) but I often "grind" with my drill...as I call it
