Rail mount Tranny Cooler? | Ford Explorer Forums
DocVijay
Meow
Tampa, FL
1999 Sport 2WD
Does anyone have one of those rail mounted tranny coolers, those long thin ones (1.5" x 2.5" x 24")? How effective are they at cooling. Reason I'm asking is I'd like to also mount an oil cooler. I figured I could use a lregular rectangular cooler up front and then mount a rail one on, well, on the rail. Which should be mounted up front? Should it be the tranny cooler since it's an automatic? I believe that the tranny cooler unit can also be used as an oil cooler, so I could have the oil on the rail. Opinions? Danke.
If you decide to go with a rail mounted cooler, definitely use it as the oil cooler. The tranny needs the bigger cooler and it needs to be where it can get the most air. The oil cooler won't need much air, if you even use it at all.
