762mm
- July 13, 2004
- Canada
- '99 XLT (4x4, SOHC)
Hello,
First of all, please let me congratulate all of you active members for this great website dedicated to the legendary Explorer (I acquired one recently - a 99 XLT with the v6 SOHC). So far this site has truly helped me out more than the Haynes repair manual I also purchased for the truck in terms of maintenance and general knowledge.
I do have a small problem with the truck however, and I would appreciate any assistance. It seems that every time that it's raining, I get a small puddle of water near the parking brake pedal (which is first visible from under the gray plastic molding that touches the carpet). I've read some posts about it being the windshield seal, and already sealed the whole bottom and bottom corners of the windshield (haven't tested it yet though).
I would like to know if I may also seal the two holes on the roof that make contact with the rubber windshield seal/gasket on the outside (those factory "holes" seem to be for evacuating water from the two large grooves that stretch all across the roof though, so I'm wondering if sealing them with silicone is a good idea). I've also read that it might be caused by some leaking seals in the wiper motors' compartment, but would rather not have to take all that apart, unless proven to be absolutely necessary (access seems pretty restricted down there).
If anyone has fixed this problem and found the source, please let me know, as it seems to be a common problem according to the posts I've read. Thanks in advance, any input would be very much appreciated.
