spotdog14
- December 10, 2002
- East Lansing, MI
- '02 XLT
I posted this in the 95-98 forum, but though i might post a thread here too...
Here is my problem, ever since we got our tranny rebuilt (BTW its a 95 explorer limited) we have had a loud clunk noise coming from under the vehicle when you would accelerate from a dead stop to almost where it would shift to second gear, but would release pressure off the pedal so it does not shift, that is when you would hear the cluck. The tranny place said that it is probibly slack in your t-case/rear diff/rear drive shaft and most likely not the tranny.
My question is now since the new tranny (rebuilt) is in place is this putting more stress on the old t-case and all the slack that is in it, causing it to make those cluncks and flash 4wd lights as us randomly?
Its got 160,000 miles on it, and the 4wd low does not work, i guessing because of it never being used by the previous owner, but from what i can tell (at least last winter) the 4wd auto did work fine, how would i go about testing this without snow on the ground? i dont realy want to get stuck in a field with it not working... lol...
Anyways do you think that the slack in the old t-case and the combination of the 4wd low not working is causing an error in the system to flash the lights at us?
Thanks!
P.S. yes i know someone is going to say "search" but after 50 pages of posts about 95 explorer transfer cases everything seems to say the same thing "you should have searched before you post" and no one actually answering anything....
Thanks for any help you guys can give me... And the fluid from the t-case and rear diff look fine.
Thanks!
