Ranger Transmission Problem | Ford Explorer Forums
cowgirl18
1992 Ford Ranger
Hello every one. I am having a problem with my 92 Ranger. I had to replace the clucthplate/flywheel on my automatic transmission that is bolted to a 2.3L 4cyl. After I replaced it and put everything back for some reason the transmission dosen't shift properly. I can shift the transmission manually in the first two gears but when I get to Drive and Over-drive it want shift manually. I thought at first it may be the modulator valve but now I don't think so. Maybe the linkage or vacum line? Help.:(
