janolsson
- July 6, 2009
- Leicester, UK
- No Ex at the mo
Hi guys
I've posted this on the uk site but as we don't rarely play with auto boxes here not had any useful replies, so i'm hoping some clever people on your side of the pond can help.
UK 4.0 SOHC 1998 (5r55e?)
Basically when i put my motor back in i didn't have the torque converter (TC) seated properly back and i tried to pull the tranny and motor together with the bolts
nono: i know now!). I realised that this wasn't the way to go so i pulled the motor out of the way again and seated the TC. it went back some with some turning but when it would go back no further, whilst turning aand applying pressure i could hear a sound like cogs rubing over each other. At the time i thought this a bit odd but reasoned that as it was only when applying pressure it would be ok as the TC will be drawn to the flywheel a fraction. Dropped the motor in and had no problem mating the 2.
Once it was all back together i fired her up and now gwt a loud rattling that sounds like its coming from the TC area of the tranny (def front end). Took a little drive around the block and it shifts fine both forward and reverve and goes into 4x4 Hi and low.
So the question is have i damaged the TC or is it likely i have done something more severe???
Sorry for the essay but i thought it best to give you as much info and background as possible.
Please help, i'm desperate to get her back on the road, it's been too long driving euro boxes.
Thank you in advance
Regards
Regards
