eddie_19852004
- June 23, 2008
- Independence, Missouri
- '01 Sport
I have a 2001 Ford Explorer Sport. 4.0 SOHC 2WD with 153,x.. miles on it. Lately I've noticed if I stop at a stop light on a hill, nothing really steap or nothing, and I start to accelerate, there is a noticeable ping or knocking noise. usually after it has already shifted into second gear. It will get a little louder as it nears the upper range of the gear, and when is shifts to the next gear, no noise, but it will repeat when its almost ready to shift into 4th. since I have had this car, we've done all new plugs, wires, upper and lower intake gaskets, cleaned the mass air flow sensor, 2 new air filters last was a K&N, quite a few oil changes, new shocks, new front rotors w/ceramic pads, wheel bearings/seals, upper ball joints, O2 sensors up/downstream, and I think that is...One other thing I've noticed is kind of a knock when I hit hard bumps/potholes at slow speeds, only when I'm pressing the brakes...now it's turned into a knock when I turn the wheels maybe 1-3 knowcks as I turn the wheel completely to the right and everynow and then a knock as I turn it back to the left. Also sometimes it makes a knock or tick sometimes as I let off the brake as I leave a stop light...any tips, suggestions or answers would be greatly appreciated, as its driving me crazy!!!
Thanks so much!!!
