ExplorerRandall
- August 28, 2015
- NorCal
- 1998 Explorer XLT 5.0
Heya folks,
I've been doing a lot of reading on this forum for some time now, and finally decided to register. First off thanks for all the help.
I have a 1998 XLT 5.0 V8, AWD. Getting on five years of ownership. 188k miles.
Last month I did the timing chain cover, timing chain, gaskets, and this is the third water pump. Think I got it right this time. Leaky coolant no more!
I have a fearsome 'death rattle', but only noticeable when going up a significant hill, or sometimes at highway speed. Does not change speed with RPM. Consistent rattle speed through all RPM's. Might even be less noticeable when I drop the hammer.
Which leads me to think that it is not valve train or bottom end.
I just thoroughly cleaned the MAF sensor, and started changing plugs and wires. Usual tune up stuff. Still got the rattle as of now.
Noticed there are two bolts missing from the exhaust manifold. Driver side rear, and passenger side front bolts are gone. A small mirror confirms that the holes have threads in them.
I'll proceed with an update tomorrow. Not looking forward to doing the top end and hoping to resolve the issue without that, or redoing the entire exhaust.
I noticed that two, TWO exhaust manifold bolts are missing.
Also unresolved. Have a check engine light, which comes on more than not. Sometimes not. P0340, but I switched the cam position sensor a few years ago, and used the special tool. Might need another alternator.
