UMD
- August 10, 2011
- 2000 Ford explorer
For the last few months I've been hearing a light clicking noise from what I thought was the back left tire. The noise was intermittent and only occurs when traveling around 5mph as when slowing down, however is present with and without brake use. Sound is like dropping a rock in an empty tin can.
I jacked up the truck today and searched the tire, and found no problems. As i slowly turned the tire I eventually heard a low clicking noise, but from the rear right side. Upon looking at that tire I noticed it had plenty of grease on the rim. Pulled the tire and saw the axle seal was leaking, and had in / out play of maybe 1/8". Spun the wheel and continued to hear a scraping noise. Pulled the rotor and found both emergency brake shoes were separated and free floating in the rotor.
I never use the emergency brake, so I am not concerned with that at the moment.
However I am wondering if I need to replace the wheel bearings, or if I can just do the seal?
I found the sticky where you open the rear differential cover to do this, but also saw a youtube video for a Ford Ranger where they didn't mention the rear diff at all, and just pulled it from the outside.
How do I get the part of the wheel with the lug nut studs off so I can access the seal?
Thanks.
Thanks.
