Rear Axle | Ford Explorer Forums
Rear Axle
ruzztec
McCreary County,KY
92 XLT 4.0/99 XLT 4.0
Does anyone know how much gear oil you put into the rear axle to refill it?
Usually about 4-5 qts.
Thanks. I was not sure and the haynes just says to use the correct amount
So..should I just put 4 in and if it can hold 5 put 5 in?
the 1994 owners guide says 5.5 pints (:us: measure) and 4 ounces of friction modifier if equipped with the factory limited slip
keep filling it till it comes out of the fill hole... then toss the cap on.....
Well then. I have the axle out of the car, On two wheels and was just tipping it down. Filling from where it poured out at. There is a fill hole. Is there another method of filling it up?
nope thats it...
I put 3.74 quarts in and made a gastek pu the cap on. Sound good?
sounds about right.
