Rear bump stops? (SOA + Shackles 35s) | Ford Explorer Forums
SuRrEaLNJ
IM BACK!
out of my mind...
1994 X 2015 JK 97XL1200C
heres somethin that i havent really seen to much discusion over. whatever there is is burried in other threads it seems
After this weekend i have found that my current setup comes in way to much contact with the body. I have regular universal replacement bumps from the napa in the back and i need something a bit longer i think. nothing bling or fancy, just like a longer then i can find stop.
wich brings me to pose the question, what are some of you guys with similar setups running for rear bumps
Do you still have the stock spring perches on the axle? If so just drop the stock bump down about 6" with some square tubing. make it up so the bump hits on the stock perch.
Either this way.
Or I was really thinking
still have the perches in there... yea, i guess thats way easier of a solution then i anticipated running into...
