cdsl227
- June 25, 2001
- Brooklyn, NY
- 2001 Explorer XLT
Ok, so I decided to try my hand at fabricating a rear bumper and coming up with something to kinda match my front.
I had some steel cut and had them put some rough cursory bends in.
Some of this steel is also going toward my SAS, but I measured things out and ordered it with enough to pretty much cover both projects.
The first shot is the side plates that are going to replace the chrome between the original bumper and the rear wheels...I'll be cutting the thin metal behind the chrome to make room.
Some 3/8 angle, maybe brackets...I'm bouncing 2 ideas around at the moment.
A 67" piece of 10 gauge that'll be the outer shell, it's rough because I'm planning on putting a few angles into it to make it look sharp and somewhat match the front.
Top step is 10 inches wide, rear is 9 inches high and it's bent in to 8 inches...if that makes sense.
The 4x4x50x1/4" Box Tube I'm using for my air tank...in this shot I just cut the cap for one end.
The Tube.
The end caps.
This piece is probably going to end up as part of the brakets.
The box tube sealed with a threaded port for the quick connect for an air hose.
Done with the air tank- I ground down the welds a little and cleaned it up, then tested to see if it held air...130psi and not a peep.
By the way if this comes out the way I want it to- which basically means looks half decent
1 - 2001 Explorer XLT Chrome Rear Bumper
2 - Opposing side Chrome Plastic thingys
Free to a needy Local Home! First come first serve!
The Tube.
The end caps.
