Rear Diff Seal | Ford Explorer Forums
Rear Diff Seal
Jason_25
Elite Explorer<br>ECX Member
New Bern, NC
'95 Explorer "Expedition"
Here's a noive question to you guys. How do I make the rear axle cover and the flange perfectly clean so I can install sealant on it? Can I use a wire brush?
A wire brush is excellent then clean the area off with any type of solvent before you apply the RTV sealant,
this will allow good adherence to the metal.
Sweet thanks Gary for the quick response.
I got a gasket for mine, when I had to replace the pinon seal and the fluid (100,000 Posi)
I ran a wire brush on the cover and scraped the housing clean with a putty knife.
Word to the wise, if you got a Traction-Lock (LS, Posi, etc) use the Ford friction modifier, I used the generic stuff in my dad's '87 Dakota and it chatters all the time.
How much did the gasket cost, and what is the pinion seal?
The pinion seal is something left to a mechanic if you have limited mechanical experience, but it is the seal behind the yoke on the front of the diff.
I wouldn't bother with a gasket, go with silicon, Ford used it from the factory so there cann't be anything wrong with it.
unless you got a leak coming from where the driveshaft meets the rear-end, don't mess with it. Mine was leaking, and I've done a few of them to know what to do.
I used a gasket because I'm not all that thrilled with RTV as a primary sealant.
A word to the wise, Ford puts threadlock on everything back there, so it may be tough to wrench out.
Jason,
The RTV works great as long as the surfaces are clean, and you can let the rtv sit for a bit before it is reinstalled. then let it cure for a while if you can before refilling the diff. I let mine sit over night- I do have a few other vehiocles avail so that may not be an answer for everyone.
I use lacquer thinner to clean the surfaces of the cover and the axle. Brake cleaner , mineral spirits, or some other low residue solvents work well also.
Have fun, oh yea I wear disposable rubber gloves when working with diff fluid- the smell is hard to get off your hands (or clothes,tools, garage floor etc) , something to think about. You can get a hundred pairs or so for about $7 I think.
