rear differential fluid: what to use? | Ford Explorer Forums
NisAznMonk
Eglin AFB, FL
'04 XLT 2wd w/o LSD
Howdy!
I have a 2004 Sport Trac XLT 2wd with a 3.73 non-LSD rear differential. I'm getting conflicting information in my search results on what kind of fluid to use.
Has anyone used 80w-90 in their rear differential? I found that weight here: http://www.mysporttrac.com/mysporttrac/projects/TrickFlow/Installing a Trick Flow 8.htm
Or am I supposed to use synthetic 75w-140 without the friction modifier? http://www.explorerforum.com/forums/showthread.php?t=294758&highlight=differential+fluid
There isn't a tag on my differential cover, and the door sticker has an axle code of 46.
:help: :help:
It should be 80w-90 unless you have the LSD which you don't. Same with the front.
It's in the owners manual-get a pdf version here:
Dead Link Removed
Rear axle lubricant:
Motorcraft SAE 75W-90 Fuel
Efficient High Performance Synthetic Rear
Axle Lubricant
Conventional
Axle 1.7L (3.5 pints)
Limited slip axle 4 1.5L (3.25 pints)
Limited Slip differentials must add 118ml (4 oz) of Additive Friction
Modifier XL-7 or equivalent to the rear axle whenever the axle has been
serviced.
