96eb96
- October 20, 2004
- Albany, NY
- 96 EB V6 OHV 4WD
Rear differential plug is corroded to the point where its jagged at the top. THe square drive barely goes in since the internal corrosion is preventing it.I tried cleaning it out with a screwdriver. I tried some PB and seafoam. I don't know if heat would be a good idea since the plug is so trashed also, I dont like using a torch under the truck so close to the gastank. I would probably have them do it on a lift if thats necessary. I'm worried when I turn the plug I am just deforming the square drive, so I am open for suggestions.
