jbird7262
- August 9, 2015
- Charlestown, WV
- 1999 Ranger XLT 4x4 4.0
HELP !!, I have a 99' 4x4 XLT 4.0, needs a rear diff, found 2, both are 373, 8.8 with 10inch drums, the rear in my truck is S359S and one donor rear is a 98' S354M which is 373, 8.8, 10inch brakes but (NL) posi, mine is limited slip (L). The other rear is missing the tag but came from the same year/engine 99' . All are 28 spline axles. Is there a way to find correct ratios and limited or posi from the inside numbers after dropping the cover? The guy with the rears says he's pretty sure that the one with out the tag is the correct one for my truck. I can get the frt diff transfer case and rear diff from the tagged rear end for $250, the other rear $150, any tips on decoding with out the tag?
There are no vehicals just spare parts so no vin#
