rear drive shaft question | Ford Explorer Forums
Paul Gagnon
Poseur SUV
Moderator Emeritus
Sherwood Park, Alberta eh?
1992 XLT
A question for everyone who has lengthened their rear drive shaft.
How much longer did you go?
Paul Gagnon
Calgary, Alberta
"No Brain, No Pain"
Dead Link Removed
I went 3" or 3.5". I have a 93 4dr automatic
with 5.5" superlift and rancho add-a-leafs. I run 32x11.50 BFG ATs
I had it lengthend because the slip joint was not tight. I thought it was bad. The local driveshaft place said there was nothing wrong with the joint...the driveshaft was too short. I never had a problem...but I'm sure its a lot stronger now. The shop did all the measuring.
Paul,
I have a 91 XLT 5-speed with a 5.5" Superlift. After the lift installation there was vibration and a droning noise evident. My 4x4 shop diagnosed it as the driveshaft so a new custom one was built. It is about 4" longer than the stock one. The splined slip joint is teflon coated for shock absorbtion, the stock one does not have this. Also, a shaft seal is used instead of the the rubber accordion cover, and it has a zert fitting to add grease when needed. You might as well throw some new U-joints in there while you've got the driveshaft off.
My custom driveshaft cost me $250. It was well worth it. Gone are any vibrations or noises. It's good knowing you have a strong driveshaft when you're out on the trail. My old driveshaft only had about 1.5" of stub into the shaft, making for a weak connection. My new driveshaft has about 6" of stub into the shaft, which makes for a solid connection and gives plenty of travel for suspension articulation.
Hopefully you have an experienced driveshaft person in your area. It really needs to be custom fitted to your rig for best results.
I also had my pinion angle turned up to match the output of the transfer case. The Superlift spring perches that just bolted on set the angle too low, causing some vibration. With the proper angle set, the Superlift perches were welded to the axle, making them much stronger and safer.
DOGMAN
DOGMAN,
Just replaced the u-joints on my rear shaft (stock) and greased the slip joint while I was in there. There's a blue coating on the stub end. Is this a teflon coating?
Thanks for the info guys. I needed to know how much you lengthened it because I am going to install a double cardan joint at the transfer case end of the rear driveshaft. This is approx 4" long so it will solve my length problem and vibration at the same time. Will let you know how it turns out!
Paul Gagnon
Calgary, Alberta
"No Brain, No Pain"
Dead Link Removed
CHH777,
What year is your vehicle? I'm going by what the guy who made my driveshaft told me, I never actually saw the old stub of the stock driveshaft. Mine is a 91.
Did you remove the rubber cover and take apart the stub from the shaft? If it is a blue plastic type coating, that probably is teflon. It's used to absorb shock. Like I said, my guy told me my stock one did not have this, and I trust him. My vehicle is an early production 91, so maybe it was changed.
I do know my new rear driveshaft works much better than my stock one.
DOGMAN
DOGMAN,
I drive a '94 Navajo.
Yes, I did remove the stub shaft and the blue coating is on the splines. Perhaps Mazda used a teflon coating and Ford did not?
