imp
- November 12, 2009
- 59 Ranchero F250 D'Line
Last question (or concern) before I start.
The housing shows some wear in the area that accepts the carrier race. I am pretty sure that the race spun at some point. By this, you mean the outer race of the brg. which supports the ring gear carrier? If you have access to measuring instruments, measure the diam. of the case bore with cap installed and bolts snugged, then diam. of a brg. outer race. If a BIG amount of clearance is evident, the assembly will "wiggle around" by that amount in use, allowing that amount of gear misalignment to occur as they are working. This will produce noise. ANY factor allowing the tooth contact pattern to deviate from acceptable will produce noise. Weird as this will sound, you can "save" a worn housing brg. bore by using plain aluminum foil, cut to width of brg. race, carefully wrapped around the brg. outer race before placing it in the bore. The adjustment nut will prevent foil from moving outward and being lost in the soup. If you found, say, the "spun" race had ate out 0.005" of case material, one wrap of 0.002" foil will almost get you line-to-line. A little bit of "crush" will hurt nothing, either, maybe up to 0.002" more foil than clearance; aluminum is soft, but more will distort brg. to out-of-round condition. Believe it or not, I have used this scheme many times with engine rod & main brngs., a "fix" denounced in every publication. Must not cover oil passage holes, tho!
Forgot yesterday: Get hold of a book or other source on axle gear set-up, the Ford Shop Manuals are best, IMO, if you are not familiar with tooth contact patterns. Not wanting to bore you with all this writing, but with used gears, often the ideal pattern centered on the "drive" side of the ring gear tooth, will produce more hum or objectionable noise than a slight offset outward, usually, toward the outside of the tooth. After determining that the pinion bearings rotate smoothly by hand with carrier removed, and you already have set-up and located the ring gear for good contact pattern and backlash, support the center section assembly (the case) firmly by some means (I use a big vise) with ring gear teeth facing upward, if possible, rotate the gear assembly by grasping the ring gear in both directions, with no lubrication on the teeth. This process loads the gears a bit, since the pinion is hard to turn compared to the ring gear, and "feel" for harshness, or a scraping feeling as you go back and forth. If there is quite a noticeable noisiness, you may want to: first, move adjusting nut to allow ring gear to move away from pinion by one or two adjusting holes, then tighten the other side to restore preload; this will increase backlash a bit, and USUALLY will produce quieter tooth contact. Don't be afraid of lash on the "high-side"; I've run them as high as 0.025" without any feel of it during operation.
Thanks again for the "excellent" reply. You are most welcome!!
Here's a bit of the theory on these gears. Being "hypoid bevel gears", they are: 1. Very strong. 2. inherently quiet. 3. very susceptible to loss of rigidness of set-up.
Note on ring gear, one side of a tooth's face is perpendicular to the gear face, or in-line, let's say, with the direction of the axles. This is the drive side; the other side lies at an angle, maybe as much as 45` to perpendicular. That is the "coast" side. The drive side transmits the big burden torque of moving the vehicle forward, while the coast side merely transmits torque back to rotate drive-line parts while decelerating or going downhill. So, IN GENERAL, the closer the contact pattern is to CENTER on the DRIVE SIDE, the better, commensurate with quiet operation. Picture that as the force is applied to the drive side face of the tooth, ALL of the force is used to turn the gear. As force is applied to the angled coast side face, some of the force is used to effectively attempt to "spread" the gear teeth apart. No problem, since "coast" produces low-torque levels.
Food for thought: Take the center section, turn it around 180`, and mount it in the FRONT of the vehicle to drive front wheels, and the COAST SIDE becomes the DRIVE SIDE, not a really good thing at all! If you are perceptive, you will have noticed that some 4X4s have their front differential mounted UPSIDE DOWN, to get back the proper tooth-torque apply orientation! Am I getting too deep?
The other thing to be mentioned is that these teeth do not "rub" over one-another during operation, but actually present a "rolling" action like a roller bearing; this drastically reduces friction and heat generation, 2 things which "eat" gears. Hope I have helped some.....imp
