rear halfshaft replacement on 2006 explorer | Ford Explorer Forums
cost of rear halfshaft replacement on 2002 explorer
Haa!! 135 views, and noone can answer my question
Who does the labor ? Part should be 100-200 I'd say.
halfshaft
thank you. the job will cost 325. includes replacing rear wheel bearing. thaks again
Good idea with the bearing when you have the knuckle out. Just make sure you use Ford/Timken brand. I had some aftermarket put in and it did not last much.
Also, make sure you get a new ABS ring ( the new thick design), it probably will come with the shaft.
