Rear heater hose | Ford Explorer Forums
Rear heater hose
mes882
iowa
2007 mountaineer prem
08 mountaineer
Looking for the part numbers to replace the rear heater hoses. Metal broke on mine were the red line is. Looking for part numbers on 2 hose connect to the heater core. and the 2 that attach just above muffer. I put red dots on those 2 hose.
For now i bypassed the rear heat with a u shaped hose. What did you to fix yours? Heater hose ran to rear heater core lose the pre shaped hoses? 5/8 hose coupling with clamps through the plate?
Is it just the hose clamps that failed causing the hoses to leak? I replaced the old spring style clamps with a small size stainless worm gear types that seem to be holding up well.
Hi
Ive purchased two outer standard rubber heater hoses on rockauto a 5 years ago.
Needs to be trimmed a bit and good to go.
The crimped inner ones is ford original motorcraft heater hoses.dont remember the p/n ( found at ford.parts.com diagrams)
I was hoping it would have been that simple.
No the metal nipple that comes down broke off flush on one side. See pic with red line.
