You sure its the seal and not the upper pan gasket? They use a one piece gasket on the cradle, but it has the rubber gasket, kind of like the old chevy 350 did, around the bump for the crank shaft. They do like to leak from there. You need to pull the motor or transmission to get at the rear seal, the pan can be pulled in the truck but its still a real dog to get out.
