Rear pneumatic failure. Fault code C1726. | Ford Explorer Forums
caravanmad
1998 explorer 4.0
hi. i have a 1998 exp and wondering if any one can help, my suspension light comes on after 10 miles i switch the car off, start up again and its fine until about another 10 miles, any suggestion and how do i now its working.
Hi, and welcome to the forum.
I had the same problem has you, replaced my shocks with Monroe 40006 and 40007 which use the same airlines as OE shocks, no problems since apart from I constantly watch my dash for the light coming on!
Terry.
Just a thought I bought from Rockauto.com have a 5% discount code valid till 19th July. Enter in "how did you find out about us" box at check out code is 17630231494431
Terry.
thanks terry, would think about doing this, as i notice this problems happens alot, and i won,t have 2 worry about that warning light, mind u i would disconect it just in case
andy
Arc
Hi,
Sorted my ARC light problem it was a corroded air line and not the shocks Phew! Cheers Terry for the link with Rock Auto.
