Rear speakers no sound | Ford Explorer Forums
Prism19
Stamford ct
2016 base ford explorer
Please help ...rear speakers stop working. front speakers works. Also have a power subwoofer tap on the rear speakers wires work. I even try changing the head unit trying to figure if the pre amp is blown but is not. I also check the wires. Are there fuses for speakers?
Shouldn’t be any fusing on the speakers.
Stock head unit? What year?
Are you sure the speakers are good?
Speakers are good . Is a 2016 ford explorer base model. Im using factoty radio. I tried switching it w another factory radio to see if the unit amp is broken. What could cause speakers not to work? And the other thing the power subwoofers works ..subwoofer wires are tap into the rear speakers
Thanks
Obviously signal is getting from the head unit to the line out converter or the sub wouldn’t work. If the sub volume is good, I’d suspect it’s the problem. I’d remove it entirely and test.
True hmmm thanks dude ill keep you posted
