dent
- March 24, 2004
- toronto
- 2013 Explorer Limited
oh my this is going to be a serious pain....
when i did mine, i used tried a slide hammer, heat, soaking it in penetrating fluid for a day or so spraying 2-3 times a day, an air chisel (mind you my compressor is just a tiny pancake which probably couldn't build up enough pressure).
I eventually gave up and too the whole hub assembly off and took it to a shop that had a bigger compressor than what i had and they eventually got it off
when putting the bearing on, i lathered it up with anti seize incase i need to replace it again
edit
here's the link to my post regarding this
Wheel bearing DIY? not really....
edit
