Hey gpaps, I noticed that you posted 6yrs ago but still I want to mention that I was having the same problem (I always heard the motor working but no water on the rear windshield) on my 02 xls until this morning (I bought it 8 months ago
. I follow some comments on the net about checking the splice under the hood, on the passenger right side and the very end on the rear light but nothing happened, so this is what I did:
- I disconnect the splice under the hood and the water was coming out... so the problem was on the line somewhere between the front passenger side and the end of the line at the courtesy light.
- I checked the passenger side and I couldn't find any splice there, so I just checked that the line was not cut...
- I went back to the end of the line and first I checked that the orifice was not clog, I wasn't sure if it was or not but I still use a needle to open the orifice in case that it was clog... then I went in into the trunk and take out the trim on the roof and the trim on the right side corner... First on the top of the roof I looked for the line to see if there was another splice there or not... and no splice however there is something like a little splitter right before the line gets into the courtesy light. I took that out to see if it was clog but it was ok... then I followed the line to the right side corner and I found a splice right there and at that moment, I noticed that one side of the line was disconnected... after I connected again, the water on the rear windshield was working again, after I don't know how much time (at least 8 months with me)...
Please note that I knew that the motor was working so if this is the case of someone else, just follow the line until you find something like this... it's pretty easy...
Hopefully this helps someone else...
